Online Now [89]:
Visitors: 88
Today: 4540
Total: 139079316
Forums › The Car › 206 Problems › Coolant tank empty - clouds of smoke
LeeUK
PostPosted: Thu Nov 28, 2013 4:54 pm Up
Driving along today and car felt funny, all jerky and lumpy etc. Then a bit later on I notice clouds of smoke out the back window so I pull into a garage and they took a look.
Turns out the coolant expansion tank is bone dry and that I've had oil in the water too. They say that it has mixed with the rest of the oil and got into the cylinders etc.
They said that my head gasket has gone and not to drive it. Does this sound right about head gasket gone?
They put a little bit of coolant in it to get me home (only half a mile down road) but the smoke wasn't bad this time. Got home and it's bone dry again. Topped it up with coolant and water mixture and it starts chucking out smoke again after it has warmed up a little.
Coolant tank was full couple of weeks ago when I glanced when I was filling screen wash up but it was probably full of oil and water.
2001 206 1.4i GLX
2001 Megane 1.6i Dynamique 16V
2008 207 1.4 HDI
2014 Focus 1.6 TDCI Titanium Nav
2020 Jaguar E-PACE Chequered Flag D150 AWD + 2002 Ford Focus 1.6 Ghia run-a-bout
MrZiggerz
PostPosted: Thu Nov 28, 2013 5:44 pm Up
Sounds like headgasket failure to me.
Its a pricey job.
ukskater01
PostPosted: Thu Nov 28, 2013 5:45 pm Up
Sounds like headgasket to me. Might be cheaper to get a second hand engine and swap it
PostPosted: Fri Nov 29, 2013 3:54 am Up
Just get the gasket changed. No way will it be cheaper to fit another engine.
PugJH
PostPosted: Fri Nov 29, 2013 4:07 am Up
What do people class as pricey now adays. Head gasket on that engine done professionally shouldn't cost to much. Not as much as other cars on the road.
WIP: Black 1.6 16v XSi
Beauté Noire
LeeUK
PostPosted: Fri Nov 29, 2013 6:59 am Up
How much would this cost at your average garage? I don't have facilities to do anything like this myself.
2001 206 1.4i GLX
2008 207 1.4 HDI
PostPosted: Fri Nov 29, 2013 7:44 am Up
Get some recommendation from friends and ring around. relatively simple on this engine so doesn't have to be a main dealer task. I bet it still hits your pocket to near £300 and maybe a little more.
PostPosted: Fri Nov 29, 2013 8:19 am Up
It's any other damage that has been done to the internals that would be my worry. 10 litres plus of coolant mixed with the oil wouldn't do it any good.
You wouldn't really know until the head is off and it can be seen where the gasket has failed.
An engine change might work out cheaper and easier in the long run.
marnemainia
PostPosted: Fri Nov 29, 2013 12:01 pm Up
If its got that hot, be sure to have the head skimmed before fitting head gasket
LeeUK
PostPosted: Fri Nov 29, 2013 7:34 pm Up
Thanks, not sure if it's all going to be financially viable as it has also failed MOT on both upper strut bearings, brake pipes, and rear brakes. £250-300 at a garage for those at least.
2001 206 1.4i GLX
2008 207 1.4 HDI
PostPosted: Sat Nov 30, 2013 5:01 am Up
That lot isn't expensive to fix...all cheaper than a new car.
LeeUK
PostPosted: Sat Nov 30, 2013 6:10 am Up
Yes parts are cheap but that's garage prices unfortunately.
2001 206 1.4i GLX
2008 207 1.4 HDI
206Info_SW_Scots
PostPosted: Tue Dec 10, 2013 3:15 pm Up
If it's a 2001 and high mileage, time to change the car.
206 SW 55 Plate - Happy Owner
LeeUK
PostPosted: Tue Dec 10, 2013 4:09 pm Up
67K miles.
2001 206 1.4i GLX
2008 207 1.4 HDI
PostPosted: Tue Dec 10, 2013 5:19 pm Up
Shame you haven't got a knowledgeable mate. DIY would easily make it worth saving if the body and interior are good.
I sold my daughter's several months ago; it was a very nice example, almost immaculate, with history "W" plate 2000 car. Sold for asking price of £650 and probably a little under priced as the phone rang off the hook but it was a well maintained car (by me) with lots of history. The buyer tried to haggle on the phone but once they saw it then bought it without a hint of asking for money off and I declared that the cam belt was due.
