Latest: sparrowdclxvi
Overall: 17139
Online Now [104]:
Visitors: 103
Today: 33178
Total: 112995060
Forums › The Car › 206 Problems › 206 coils prings
206 coils prings
2stroke
PostPosted: Mon Dec 02, 2013 5:51 pm Up
is there a specific way the springs on the 206 should be inverted on new shock bodies. finishing a job and am not sure ! the springs is fitted with blue dots at the bottom if that is relevant...... Confused Question
PostPosted: Mon Dec 02, 2013 10:32 pm Up
Not relevant.
Blue dot is not for orientation, it's identification for stiffness length etc on OEM springs.
Make sure the 'ends' are seated properly on the small step on the damper and the top mount and that's it.
2stroke
PostPosted: Tue Dec 03, 2013 9:27 am Up
spring is defo not located properly in top mount ! going to remove and invert the spring as i think it was fitted upside down by yours truly.....
