Online Now [386]:
Visitors: 385
Today: 100555
Total: 155970567
Forums › The Car › 206 Problems › 2000 1.1 regular coil pack failure
PostPosted: Tue Dec 03, 2013 4:51 pm Up
A friend has a 1.1 that seems to suffer regular coil pack failure every 2 years or so. I have not looked at the car and only just got to hear about this from my wife as it is her friend.
A quick look on the net and it seems there is either a black or grey type plug on the coil pack and I assume that is car dependent also prices vary from about £30 to £140. Are the cheap ones to be avoided at all cost (it is an old car and they don't have much money) and is there any reason these fail so often?
I don't know if previous replacements have been genuine Peugeot or not and whether cheap pattern part is reason for failure. That would be an easy to conclude reason but are there any other reasons that these fail so often?
PostPosted: Wed Dec 04, 2013 3:43 am Up
Anybody? Shameless bump.
gazza82
PostPosted: Wed Dec 04, 2013 9:00 am Up
There is a make of pack that doesn't like certain plugs ...
PostPosted: Wed Dec 04, 2013 9:29 am Up
www.206info.co.uk/Foru...c/t=22764/
gazza82
PostPosted: Wed Dec 04, 2013 9:35 am Up
That's it .. Smile
PostPosted: Wed Dec 04, 2013 10:25 am Up
OK, I looked at the colour issue a while back.
1) The colour on the coil pack is not neccesarily the same as the connector of the loom colour: as fitted at the factory. (eg could be grey socket/black plug, or black/black).
2) If it's multiplexed there are two different type coilpacks, both with black connector on them.
3) Only way to make sure you get the right one is VIN check in servicebox to get the OEM part number and take it from there.
If the coilpacks trully are failing that often, then the ECU is faulty in all likelyhood (eg passing DC).
PostPosted: Wed Dec 04, 2013 1:17 pm Up
make sure you have the OEM spark plugs.
PostPosted: Wed Dec 04, 2013 5:23 pm Up
+1, everyone should have them. Wink
doski
PostPosted: Thu Dec 05, 2013 1:55 pm Up
eurocarparts are spot on for price i had a sagem coilpack and ngk spark plugs in mine which didnt go very well
i bought a valeo one and bosch spark plugs from euro for less than £55
also if you give them your reg theyll run it through so you dont have to worry the only difference i could tell is one connectors black ones grey
PostPosted: Thu Dec 05, 2013 3:03 pm Up
Sounds to me you might have another fault lurking about. Next time it happens, get the fault code written down!
Sageam are a grey area, we did supposedly suffer a few issues with them, but that could have been when they didn't have the condenser attached.
Genuine is normally vaelo or sageam, and if anything I rate NGK plugs better than genuine by any standards, as they are just s**t in my eyes. Taken out of one box, new label and shipped out again
PostPosted: Fri Dec 06, 2013 1:42 am Up
Yes they should Very Happy Thumbs Up
PostPosted: Fri Dec 06, 2013 8:05 am Up
Genuine are Eyquem (French) and are quite dear even directly from the manufacturer. Are you refering to Bosch which is what a lot of 'dealerships' are fitting?
PostPosted: Fri Dec 06, 2013 3:38 pm Up
Normally we are only supplied with valeo due to superceding of parts
PostPosted: Sat Dec 07, 2013 2:52 am Up
No meant the spark plugs.
PostPosted: Sun Dec 08, 2013 12:03 pm Up
the OEM ones can be Eyquem ,or Bosch ,as long that they match the part number,then there is no problem.
