Online Now [353]:
Visitors: 352
Today: 188800
Total: 155481312
Forums › The Car › 206 Problems › when engine's hot..car wont start
penang206
PostPosted: Fri Dec 06, 2013 12:19 am Up
hi all members..
my probably is when the engine is hot(after drive)..i switch off, then I can't start my car again & have to wait for a while, until engine cool a bit..by then I manage to start my engine.
206..1.4..auto..petrol..
tq bro
javascript:emoticon('post','message',':roll:')
PostPosted: Fri Dec 06, 2013 1:36 am Up
Well the problem is in your starter motor for sure,replace it with a new one OR get it out,and replace the item on top of it,not sure of the name,but you will find it for sure.
PostPosted: Fri Dec 06, 2013 3:38 am Up
Solenoid
or that's what they used to call them. Probably been changed to some fancy name by now so that they can bump up the price
macj
PostPosted: Sat Dec 07, 2013 3:54 am Up
I would check the engine temperature sensor..... these have a habit of flooding the engine when its hot if they are playing up. For the price its cheaper than a starter to start with Wink
Leegsi
PostPosted: Sat Dec 07, 2013 4:33 am Up
If it turns over but doesnt start its not your starter motor.
Get the codes read as a failing crank sensor will make a car not start when hot
rlees85
PostPosted: Sat Dec 07, 2013 6:22 am Up
I agree with crank sensor if the engine is turning... happens in a lot of cars
PostPosted: Sat Dec 07, 2013 2:19 pm Up
I would also have a punt at crank sensor but that should be stored as a fault code.
PostPosted: Sun Dec 08, 2013 12:15 pm Up
Well I'm sure it's the starter motor,or starter motor solenoid as Macca said,we will wait and see ;),as if it's a crank sensor,it will not start at all.,and about temp sensor,it's not for the 1.4,that only effects the GTi 180,time will tell,I mean when he reply back :D.
DREWDEN
PostPosted: Sun Dec 08, 2013 1:42 pm Up
All he has to do is park on a slant, switch off hot engine, if it does not start, bump start the car, if it starts then its the starter motor, if it does not start something else.
206 2ltr Hdi glx 53 plate
Leegsi
PostPosted: Sun Dec 08, 2013 2:49 pm Up
A failing crank sensor will start when its cold but when heat soak sets in it fails.
Trust me it can happen and does happen.
I had it happen to me on a Fiat.
If it is the crank sensor it would have logged a fault code so rather than guessing get the codes read first.
macj
PostPosted: Sun Dec 08, 2013 3:03 pm Up
Temp sensor is relevant in nearly all French FI engines....do your homework
PostPosted: Sun Dec 08, 2013 4:24 pm Up
Love DREWDEN's idea about parking on a slope. Try to start with the key when the engine is hot; if it doesn't start on the key but will bump start then probably not crank sensor.
Leegsi is also correct that crank sensors can fail when hot but be fine when cooled down. It is very, prevalent on motor bikes but also happens on plenty of cars.
PostPosted: Fri Dec 13, 2013 9:16 am Up
Well you mentioned it,not me,since it happen in Fiat car,these cars are bad in everything,that is why FIAT=Fix It Again Tim Wink Whistle...
PostPosted: Fri Dec 13, 2013 9:17 am Up
I will do my homework,as I have not been studying well ..lol Very Happy
