Posted: Sun Dec 15, 2013 11:07 am |
I have 2.0 HDI 03 Quiksilver and i want to know if I have a Bosch or Siemens ECU.
The fuel rail is Bosch as the end part on the fuel rail.
I have found siemens in my fusebox and added a pic of my ecu.
Also the only markings on the fuel pump under the backseat are VDO which is referring to the sender unit.
I would like it to be Bosch so I can remap. Any ideas short of removing it?
| 206 HDI 2.0 Quiksilver
Full Stainless Decat
Stage 1 Tuned | |
Posted: Sun Dec 15, 2013 12:00 pm |
You might be able to find out on servicebox in the characteristics section
Posted: Sun Dec 15, 2013 12:08 pm |
macca1411 wrote: |
You might be able to find out on servicebox in the characteristics section |
I thought you had to be in the trade in order to register and view anything on there?
Stage 1 Tuned | |
Posted: Sun Dec 15, 2013 12:25 pm |
robovw1303 wrote: |
macca1411 wrote: |
I thought you had to be in the trade in order to register and view anything on there? |
You do.
Posted: Sun Dec 15, 2013 12:39 pm |
Thought so, so anyone got any advice on seeing what ECU I have or do I have to take it out and see if there are any markings on the underside?
Stage 1 Tuned | |
Posted: Sun Dec 15, 2013 12:41 pm |
Whats your vin? (only need the last
I will have a look for you
| Team Impossible Possible
Posted: Sun Dec 15, 2013 12:53 pm |
Hmmm actually the EDC15 is Bosch right?
Last on the Vin is : 43393020
Could you tell me my paint code whilst your at it?
Stage 1 Tuned | |
Posted: Sun Dec 15, 2013 1:40 pm |
EZR
Bosch
Any other info required?
Posted: Sun Dec 15, 2013 1:58 pm |
Addaz wrote: |
EZR
Bosch
Any other info required? |
Legend thanks!!!
Stage 1 Tuned | |
