Posted: Sun Dec 15, 2013 4:55 am |
Hi guys. My 106 daily has started squeaking from the rear whenever I stop accelerating. I will take my foot off the gas as I approach a roundabout for example, and it'll squeak. It won't squeak when I'm braking, turning or accelerating. Any help would be greatly appreciated.
Posted: Sun Dec 15, 2013 12:36 pm |
sounds like the start of a axel problem
but might just be a bush
Posted: Sun Dec 15, 2013 12:38 pm |
I've been toldit may be the brake shoes (which need replacing anyway, awaiting delivery ofthem), may be a wheel bearing, or may be shock absorbers
Posted: Sun Dec 15, 2013 2:47 pm |
Dont rule out exhaust movement either, my old vts had a squeek like you are describing and it turned out to be my exhaust, took it off, bit of copper grease here and there (bushes etc) and it went. Check everything else shocks axel etc whilst its in the air too.
Posted: Sun Dec 15, 2013 2:48 pm |
I did have a new exhaust fitted (pugsport) but my mate who fitted did say I need a fitting kit for it to be on properly, so may be that...
