Latest: Mr-Koekwaus
Overall: 17125
Online Now [94]:
Visitors: 93
Today: 9008
Total: 99978946
Forums › The Car › 206 Problems › Boot does not open Strangely?
very_452001
PostPosted: Mon Dec 16, 2013 6:53 pm Up
After driving on the motorway yesterday for about 90 mins and after arriving at my destination I notice boot did not open except all 4 doors that did open. Checked remote cental locking and key however boot did not open.
Strangely after doing the return journey back and arrived home the boot did open.
Car is 206 1.4 8v TU3A Engine 2006 Verve.
What caused this problem?
very_452001
DSWR
PostPosted: Mon Dec 16, 2013 7:03 pm Up
I had that earlier, boot wouldn't open, locked it up again, then locked it, tried to open it, and it worked? think it's just a low battery on either the car, or your key. My key's battery is on it's last legs, so could be related to that?
GTi 180 owner!:)
www.facebook.com/notdanwhite
RockRulz
PostPosted: Mon Dec 16, 2013 11:09 pm Up
Mine is the opposite. Won't lock with the central locking. I've had to close it down, get in the boot from the back seats and undo the latch rod to make it safe......won't UNDO now....full stop. New actuator needed I think. I hope you get yours sorted.
www.facebook.com/Hazel...rington151
PostPosted: Tue Dec 17, 2013 7:51 am Up
Well your boot motor might be weak,so spray some DW40 on the lock itself,and see how things goes.
very_452001
PostPosted: Tue Dec 17, 2013 6:46 pm Up
ok will do that. thanks for the advice Thumbs Up
very_452001
PostPosted: Tue Dec 17, 2013 9:12 pm Up
DSWR wrote:
I had that earlier, boot wouldn't open, locked it up again, opened it, and it worked? think it's just a low battery on either the car, or your key. My key's battery is on it's last legs, so could be related to that?
I can't see why the boot-lock motor would care if the keyfob battery was weak?
This would just give reduced range and missed codes/
PostPosted: Wed Dec 18, 2013 5:36 am Up
I know that this might sound like a daft suggestion, but have you removed the trim from the inside of the boot and checked whether its the motor or the handle that's faulty. Could be something very simple like a dodgy clip.
