Online Now [1159]:
Visitors: 1159
Today: 3525
Total: 155305625
Forums › The Car › 206 Problems › Grinding noise on acceleration
karimali831
PostPosted: Tue Dec 17, 2013 9:34 am Up
Hi,
I have recently noticed a grinding noise when accelerating, it sounds clear in gear 1, gear 2 you hear it slightly and the other gears you don't notice. It maybe like a metal-to-metal contact? 2011 March I had a new clutch, for sure gone a lot heavier since and clutch pedal annoyingly squeaks so maybe something behind this? Other concern is water pump was never changed and I am at 110k miles.
Any thoughts?
206 GTI 180
PostPosted: Tue Dec 17, 2013 10:46 am Up
how many miles have you done using the clutch since 2011??,clutch pedal is heavy,maybe you have a problem with master cylinder,as it adjust the clutch depending on it.
Well I recommend that you do a whole timing belt kit replacement,as 110K is much for a water pump,and it may fail at anytime,and it's not right ,to change the water pump,and keep the old timing belt with it's tensioner.
karimali831
PostPosted: Tue Dec 17, 2013 10:55 am Up
It has done about 24-25k since change. My timing belt was also done around same time as clutch 83-84k but no water pump. So I should change the belt again with the water pump although the belt has only done 24-25k ?
206 GTI 180
PostPosted: Tue Dec 17, 2013 11:33 am Up
it's the safest work can be done,so you don't have any issues related to timing belt what so ever,the mechanic who done the timing belt should of advised you to do so,so that you don't think of redoing it again as now,and it don't cost much as for labor
PostPosted: Tue Dec 17, 2013 12:51 pm Up
First motion shaft bearing has failed. Very common issue
Gearbox rebuild required or replacement box
