Online Now [466]:
Visitors: 465
Today: 119728
Total: 156997537
Forums › The Car › 206 Problems › 206xsi Low power
206xsi Low power
silverfox1264
PostPosted: Wed Dec 18, 2013 7:45 am Up
I was driving my car when it seemed to have a loss of power pulled over turn car off & back on all was ok. Then driving home the engine management light came on. I disconnected the battery reconnected it now the car seems to have total loss of power not enough power to reverse the car. Rev's wont go abover 1000rpm.
Im thinking it's gone into limp mode? Anyone got any ideas?
im new
DREWDEN
PostPosted: Wed Dec 18, 2013 10:54 am Up
The diagnostic light eluminates when you have an emmisions problem, try this method i read somewhere to come out of limp mode as a temparary measure.
With the ignition turned on leave on for 10 secs or so not touching the accelerator pedal.
Then switch off the ignition and leave for 15 secs.
Now see if it has come out of limp mode, and also see if the EML light has gone out.
206 2ltr Hdi glx 53 plate
silverfox1264
PostPosted: Wed Dec 18, 2013 2:05 pm Up
Hi,
I tried the above but no luck, any other ideas? I think I'll have to join the AA get them out. Not a good time of year for the car to stop working.
im new
ukskater01
PostPosted: Wed Dec 18, 2013 3:56 pm Up
You will have to pay extra if you ask the aa to come out to you while your joining. I had a flat tire on a Sunday and the crappy space saver valve blew out! I joint the aa over the phone then asked them to come out. They said I would have to pay extra. Ended up taking my alloy in a minicab to Kwickfit (only place open). Still kept the cover though as I had to use it a few times Smile
ukskater01
PostPosted: Wed Dec 18, 2013 3:57 pm Up
You would be best to try and get it to a trusted garage that could carry out diagnostics or have look on the Peugeot planet map on here to see if anyone is close to you
ukskater01
PostPosted: Wed Dec 18, 2013 3:59 pm Up
maps.google.com/maps/m...9832052ecd
PostPosted: Wed Dec 18, 2013 4:01 pm Up
Get the codes read and take it from there.
