Online Now [476]:
Visitors: 474
Members: 1
Today: 67184
Total: 156174399
Forums › The Car › 206 Problems › Airbag warning light
bukko
PostPosted: Fri Dec 20, 2013 9:19 am Up
Hi,
my missus's 206cc has had an airbag warning light ever since we bought it, although it "apparently" went through the MOT with it.
Is this likely to be something as simple as a fuse? Ok I think I know the answer to that, but are there any common causes?
Thanks all.
Smile
206HdiGti
PostPosted: Fri Dec 20, 2013 9:44 am Up
Check the connection underneath the seats
bukko
PostPosted: Fri Dec 20, 2013 10:38 am Up
Will do thanks!
Smile
PostPosted: Fri Dec 20, 2013 3:13 pm Up
best way to handle such a problem,is to have diagnostic ,as it will tell you what is wrong and where in the Airbag system,check the PP2000 map,you might find someone close to you who welling to help.
ukskater01
PostPosted: Fri Dec 20, 2013 6:54 pm Up
Mine use to do this, just had to push in the plug under the dash by the fuse board. Bad connection but only came on twice so didn't bother cutting and soldering
