Posted: Tue Apr 02, 2013 6:10 pm |
I cant get any washer fluid to come out of the bottle and onto my windscreen
I pull the washer stalk but no sound is made, I have taken it to a garage and they have said that the pump itself is fine and the fuse was blown however with a new fuse it still fails to work.
They suggested a electronic problem.
Anyone know the problem, fix or any info to help?
Posted: Wed Apr 03, 2013 2:51 am |
dead motor? Its located on the washer bottle! Try a different fuse though and make sure it been put back in the right location!
Posted: Wed Apr 03, 2013 5:12 am |
def check the fuse,and that its inserted properly,mine has a weird ability of removing itself from the slot on the washer jet for some reason
| Joined the GTi massive 10/1/13
Goodbye lairy Pugani (quicksilver 1.4)  | |
Posted: Wed Apr 03, 2013 12:52 pm |
Probably the motor is dead,best way is to take the wheel liner out,check the plug if there is voltage when someone press it,if not then the fuse is blown
Posted: Fri Dec 20, 2013 11:09 am |
I am currently having this problem. The pipes and jets are clear, I have changed the pump and the fuse, the washer still doesn't work.
Could there be an earth fault or something else? I am at a loss to figure out what it is.
Posted: Fri Dec 20, 2013 2:50 pm |
| clintyfitz wrote: |
Could there be an earth fault or something else? I am at a loss to figure out what it is. |
Get to the plug on the motor and disconnect. Voltmeter to the plug:
| Code:: |
(Trying to use indentation for conditional testing dependent on y/n answers.)
12V? No? -> Measure positive lead against a good ground. 12V then?
Yes?->bad ground connection.
No?-> bad positive feed.
Check continuity on the ground wire to good earth to
check the ground wire as well (so there's not a double
fault).
Yes? -> Is the motor known (tested) good? If not, test it with temp wires
from the/a battery. If if it works then you might have a high resistance
connection in the wiring (ie measures good 12V with a high resistance
load like the meter, but prevents the motor from drawing the much higher
current it needs.
Other then that I'm out of theories...
| Silvermetallic 2004 206 RC | |
