Latest: DanDan17
Overall: 17128
Online Now [43]:
Visitors: 42
Today: 26653
Total: 100501437
Forums › The Car › 206 Problems › 1.6 hdi radiator replacement
206HdiGti
PostPosted: Fri Dec 20, 2013 6:49 am Up
2005 1.6hdi
After over a year of having a slight leak in my radiator all of a sudden it's gotten worse and i've had to buy one.
Is it relatively simple to change one yourself?
I need a guide or a walkthrough if anyone has one?
Cheers
iainlovatt
PostPosted: Fri Dec 20, 2013 11:55 am Up
Dead easy, 4 bolts. Couple connectors and 2 pipes Smile
(My Garage)
PostPosted: Fri Dec 20, 2013 2:56 pm Up
it's the simplest thing you can ever do by yourself,nothing tricky in it,straight forward job,but don't forget to bleed the coolant system when you are done.
206HdiGti
PostPosted: Mon Dec 23, 2013 2:26 am Up
Are the bolts the torx ones on the top?
PostPosted: Mon Dec 23, 2013 8:03 am Up
Yes they are the ones that hold the top of the radiator in place.
