Posted: Fri Dec 20, 2013 2:57 pm |
i have a Peugeot 206 quiksilver.
recently taken to the local garage to have a wheel bearing changed on the drivers side. once leaving the garage i noticed i had an annoying constant squeak and clunking when pressure applied to the breaks.
I took my car back to the garage less than 3 days later explaining the sounds and took it for a test drive to show a mechanic the sounds.
they replaced the brake pads of both sides which solved the clunk but still had the squeak.
Dad and i looked ourselves and the brake disc looked warped so changed the disc and noise had gone for a day. now still have the annoying squeak and now a grinding/rubbing noise when brakes applied...
anyone who may know the problem i would be very grateful as this car is my pride and joy and my baby !!!
Posted: Fri Dec 20, 2013 3:29 pm |
Well I believe the sound you got is cause by the protector of the discs,it's the metal plate behind the discs,take a look at it,and make sure it don't touch the discs in any way,and maybe it got bent while working on your car,specially from the down part.
Posted: Sat Dec 21, 2013 9:02 am |
I dont have a splash shield. so its not that rubbing. thank you for your advice. any other ideas would be grateful.
