Latest: DanDan17
Overall: 17128
Online Now [59]:
Visitors: 58
Today: 29218
Total: 100549115
Forums › The Car › 206 Problems › rear beam pivot shaft ??
mjsroofing
PostPosted: Sun Dec 22, 2013 2:47 am Up
Other than the one on eBay does anyone know where I can buy them.
I am in the middle of rebuilding a rear beam.
I have changed the beam on it twice and they have gone within 6months of each other so I thought I'd rebuild the old one and fit that.
Not that hard to do once you worked it all out.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Sun Dec 22, 2013 3:34 am Up
How do you get the pins out of the beam?
mjsroofing
PostPosted: Sun Dec 22, 2013 3:40 am Up
Not sure yet, hammer and chisel maybe.
Drill a hole straight through and slot bar in hole and turn shaft ??
Its worth a try as the beam is scrap as it is.
Mark
PostPosted: Sun Dec 22, 2013 9:55 am Up
When I had my axle replaced I'm sure they just hammered them out.
mjsroofing
PostPosted: Sun Dec 22, 2013 11:17 am Up
Did you see them hammer it out, can you describe how they managed to do so. With out looking at it again I would think to hammer it out you would have to remove the other trailing arm and insert a very long chissel from that end through the centre in order to hammer it out.
Mark
DanT
PostPosted: Sun Dec 22, 2013 1:45 pm Up
If it was as easy as hammering the stub pins out to replace them it wouldnt be so expensive for axle rebuilds.
mjsroofing
PostPosted: Sun Dec 22, 2013 2:06 pm Up
So, is there any positive information available please. I am going to attempt the removal tomororow.
I have a few ideas but I will just have to see how it goes.
Mark
commandosqueak
PostPosted: Sun Dec 22, 2013 5:51 pm Up
Sorry bud can help with that but i did just get a reconditioned axle from axledirect.com with two years warrenty for 275 delievered to my door
Smile (last resort)
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
mjsroofing
PostPosted: Sun Dec 22, 2013 6:00 pm Up
Smile (last resort)
Yep this is going to be my last resort. I have already got to the point of looking.
I have already bought and fitted two new trailing arm bearings and have all four beam bushes ready to fit.
The only reason its not on the car is the fact that the one piveg shaft is just to far gone. I am going to try removing it tomorrow.
Its should take me long to remove the trailing arm again. So I will know fairly early wether or not its doable.
Mark
commandosqueak
PostPosted: Sun Dec 22, 2013 6:02 pm Up
ok buddy good luck Smile
PostPosted: Mon Dec 23, 2013 1:54 am Up
I imagine it's a interference fit and some heat might be needed...maybe.
mjsroofing
PostPosted: Mon Dec 23, 2013 1:56 am Up
Edward wrote:
I imagine it's a interference fit and some heat might be needed...maybe.[/quote
Yes I think your
I was thinking of using a reciperating saw and cutting a slot in the centre.
Mark
