Online Now [1224]:
Visitors: 1224
Today: 441850
Total: 153837025
Forums › The Car › 206 Problems › wind + door = Problems
commandosqueak
PostPosted: Sun Dec 22, 2013 5:04 pm Up
when i opened my door the other night the wind caught it and blew it open quite hard. the door went further than it should have done. Now the door doesn't close properly meaning i have difficultly locking it. Its like it has dropped on its hinges. the door can close but i have to push it up whilst doing it. I have had a look but everything seems ok to me. the pillar and hinges look straight.
Anyone have any ideas? its the last thing i need at the minute.
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
mjsroofing
PostPosted: Sun Dec 22, 2013 6:10 pm Up
Maybe some new pins.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
DanT
PostPosted: Sun Dec 22, 2013 7:17 pm Up
Slacken off the two bolts that go through the hinges. Open and shut the door a couple of times, see if its better then re-tighten if so. Tends to sort it most times when that happens to a car.
Rob2859
PostPosted: Sun Dec 22, 2013 7:55 pm Up
Quite heavy doors on small hinges. Its never going to go down well. closely inspect the other side and check for differences. They may be slightly bent. Even the pins could be.
commandosqueak
PostPosted: Mon Dec 23, 2013 4:36 am Up
cheers guys i will have a look if it ever stops raining Sad
