Posted: Sun Dec 22, 2013 12:36 pm |
Can anyone tell me what the compression should be on a 2001 1.4 8v petrol engine. Mine read no1 70, no2 75, no3 60, no4 60. When put a teaspoon of oil down each bore they read, no1 105, no2 100, no3 100, no4 100.
Posted: Sun Dec 22, 2013 3:00 pm |
Was the throttle fully open on the test?
As it seems all low. But they are within 10 percent so technically its classified as okay
| Team Impossible Possible
Posted: Sun Dec 22, 2013 5:25 pm |
The compression ration is 10.5:1. Pug never disclosed the compression figures. as long as all is within 2 bars any more indicates a fault. my manual says as a GUIDE any pressure below 10 bars can be considered less than healthy Compression should build up quickly
| 2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey | |
Posted: Sun Dec 22, 2013 11:20 pm |
Throttle was fully open and they reached the max reading stright away on first turn of the key. My haynes manual says 10 bar which is double my readings, i know they are all well within 2 bar of each other, but the readings seem so low.
Posted: Mon Dec 23, 2013 4:43 am |
That was where i got my information from personally i would say if all the readings are consistent then dont worry
