Latest: elelectricistadeMateo
Overall: 17127
Online Now [62]:
Visitors: 61
Today: 467
Total: 100398707
Forums › The Car › 206 Talk › driveshafts and wishbones for gti 180
Johnbyron
PostPosted: Mon Dec 23, 2013 6:34 am Up
Hi everybody !
Iv not been on here properly in a long time and alot of my priorities have changed since earlier on in the year, so unfortunately I will not be going ahead with my original plans for this car Sad but none the less I shall not be getting rid.... ever!. I need a diesel for work but im going to keep the car standard and take her off the road and keep her as a very clean and garaged model as there cant be many red 180's about now (2009 apparently there were 174).
The problem is I will need to replace the wishbones and driveshafts whilst cleaning her up underneath due to the wear on the bushes and cv joints and ill be honest I dont have a clue where to get some good quality driveshafts and wishbones. Iv read a few things about euro car parts driveshaft being of a poor quality but their lemforder wishbones are good??
Any recommendations will be appreciated! Smile
PostPosted: Mon Dec 23, 2013 8:02 am Up
Wishbones will be OK if they are a decent brand but from experience ECP driveshafts are weedy splndley things whivh will enable your car to run but I wouldn't want to run much power through them. Unless ECP do CV joint kits, I'd go to the Peugeot dealer for new shafts.
Johnbyron
PostPosted: Mon Dec 23, 2013 8:58 am Up
hmmm this is the sort of answer I was seeing after a quick google search, I had considered peugeot because iv had items from them before at not bad prices, I know they'll cost more than ecp but lets face it the peugeot parts I have fitted now are original and have lasted nearly ten years so hopefully the new Peugeot parts will last just as long Smile
macj
PostPosted: Mon Dec 23, 2013 11:32 am Up
Check out GSF website for a price. I use them in my rally car with no issues to date. Wishbones are sometimes Quinton Hazel Brand which I find to be great quality. But as Edward explains, Sometimes OE is best for guarantee
Johnbyron
PostPosted: Tue Dec 24, 2013 6:21 am Up
Thanks mac , I had a look at gsf and they're not bad prices, they offer premium driveshafts so Id go for them which are a bit more costly but still a bit cheaper than peugeot
NayNay1991x
PostPosted: Sun Dec 29, 2013 5:15 pm Up
Lemforder are decent for wishbones Smile as is QH.
206 1.4i GLX 1999
instagram.com/nay206pug/#
