Posted: Tue Dec 24, 2013 9:35 am |
iv had my 206 gti for a while now and always had this judder but its got to the stage a want to fix what every it is as does get annoying on long journeys,il describe best a can.
when take off from biting point the drivers front wheels wobbles like mad and when u get moving at any speed in any gear there is a wobble from front end,the steering wheel is fine tho,any suggestions?
Posted: Tue Dec 24, 2013 9:39 am |
The only way you are going to know what is causing the problem is to get underneath and check for play anywhere.
Posted: Tue Dec 24, 2013 1:09 pm |
its been in the garage a few times and mechanic says everything is solid,a few of ma pals that are mechanics have said sounds like the stabiliser mount on the gear box,is this likly?
Posted: Wed Dec 25, 2013 1:10 pm |
I can't really tell you what's wrong with yours but I bought my gti with the same. Felt like the whole front end would Judder. I found the right hand mount was broken so replaced that, a little better. I found the left hand mount worn so replaced that, again a little better. Same with the rear mount so replaced with a polybush. Then replaced both front wishbones as they had started to knock over bumps and that has transformed the car. I still have minor Judder when pulling away but that's the clutch, and I can live with that til it needs changing.
