Latest: lio94
Overall: 17181
Online Now [53]:
Visitors: 52
Today: 41465
Total: 141183907
Forums › Tuning, Modification & Legal › Project Cars › ushers track project fully stripped and trimmed
Go to page Previous  1, 2, 3 ... 9, 10, 11 ... 16, 17, 18  Next
shell-vt
PostPosted: Thu Aug 29, 2013 5:06 pm Up
Trade Rating: +46
Have you got your suspention sorted yet? me ive just purchesed fk stuff today so im going to try that out on the back 206 first ..
york 16,3
usher
PostPosted: Fri Aug 30, 2013 12:03 am Up
It's still in the planning stage atm but should have a quote soon then I can start shopping for springs and dampers justnnot sure on what lbs to get front and back
Should be good when done though and different
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
shell-vt
PostPosted: Fri Aug 30, 2013 4:35 am Up
Trade Rating: +46
sounds good, pop them pics up buddy..
york 16,3
simpsonrc
PostPosted: Fri Aug 30, 2013 11:52 am Up
would you be interested in some fiberglass doors to save some more weight?
simpsonrc
PostPosted: Fri Aug 30, 2013 11:55 am Up
usher
PostPosted: Fri Aug 30, 2013 2:08 pm Up
i was planning on using twin wall grenhouse plastic sheet but thanks anyway
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Fri Aug 30, 2013 2:15 pm Up
project thread WIP
garage
FAQ
206 gti firedance
shell-vt
PostPosted: Sat Aug 31, 2013 5:10 am Up
Trade Rating: +46
yer so just returns back to same pipes really yer.
york 16,3
usher
PostPosted: Sat Aug 31, 2013 6:28 am Up
yeah nice and simple
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Sat Aug 31, 2013 12:05 pm Up
to do list
finish removing wires, neaten them up
fit fuse box back and steering wheel, speedo with dash support
grind down lugs and fill holes from removing things
relocate battery to boot or rear footwell
re fit front end and fill coolant
make brackets for bigger discs
buy and fit buckets
fit harnesses
buy and fit catch tank
buy and fit oil cooler
buy and fit bonnet pins
buy and fit discs and pads all round
buy and fit one tyre as it blew
get cage made with rear springs
get polycarbonate windows made
remove window motor
cut door inner pannels and make door card
long way to go i think
project thread WIP
garage
FAQ
206 gti firedance
shell-vt
PostPosted: Sun Sep 01, 2013 8:12 am Up
Trade Rating: +46
usher can we pop over to look at what goes were please pm me address thanks michelle..
york 16,3
usher
PostPosted: Sat Sep 28, 2013 6:38 am Up
another little update
managed to find some bucket seats for 40 quid the pair
hopefully i will resolve the non starting issue i have had for a few weeks tomorrow seams to be imobilizer and lack of wires that are needed as i started cutting from the fuse box and bsi
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Sat Dec 28, 2013 1:17 pm Up
finally got some wires for the loom so when they arrive i should be able to get it running again, its been put back together and cleaned prior to winter and covered with a car cover, only thig is where do these wires go in the bottom left
once its running again time to start installing the seats and getting some runners to keep it being able to move as i might not be the only driver, got some plastic sorted for the doorcards so can start on them also
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Sat Jan 04, 2014 12:05 pm Up
got the car started for the first time in months today, it sounded a bit tappy to begin with but calmed down after 10 mins,
start
how things were left with lack of light and the car worked so job done really
just need to check the fan works as it didnt come on in 15mins of running, check the coolant is air free again, wire up speedo, fuse box for headlights, tidy all wires up and then i can start on other things
how can you tell if the coolant is circulating other than feeling the pipes as im not 100% watter bottle was warm all pipes were warm and rad
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sat Jan 04, 2014 2:31 pm Up
passenger seat looks a little small mate Laughing
Page 10 of 18
