Latest: elelectricistadeMateo
Overall: 17127
Online Now [61]:
Visitors: 60
Today: 10845
Total: 100409048
Forums › The Car › 206 Talk › Bosch or Valeo Coil Pack?
NayNay1991x
PostPosted: Sun Dec 29, 2013 5:07 pm Up
Bosch: £55
Valeo: £90 (if I can remember)
If these do the same job would bosch still be good for a coil pack? Or you guys prefer valeo at all?
206 1.4i GLX 1999
instagram.com/nay206pug/#
PostPosted: Sun Dec 29, 2013 6:53 pm Up
Either will be fine. Just avoid Bougicord
PostPosted: Mon Dec 30, 2013 1:23 am Up
No Bougicord is fine, Sagem were the one's to avoid but that was ages ago..
Ste
PostPosted: Mon Dec 30, 2013 4:21 am Up
Staff - Ste
Yeah avoid Sagem like the plague, nasty things those ones!
Bougicord was the higher end/better quality 'replacement' for the failing Sagem ones IRRC. Valeo ones are a good choice too, I've never seen a Bosch one myself..
The Cars:
NayNay1991x
PostPosted: Mon Dec 30, 2013 7:44 am Up
Hm, BOSCH normally are decent for most stuff but I got a few stuff on the car that's Valeo but none of its failed yet. So I'll probably just go for the Valeo one.
Thanks. ☺️
206 1.4i GLX 1999
richpowell91
PostPosted: Mon Dec 30, 2013 11:37 am Up
Is yours the black or grey plug one mate?
www.ebay.co.uk/itm/PEU...53f8217e52
If its black thats a genuine bougicord and they accepted £20 plus postage when i offered when i brought one.
PostPosted: Mon Dec 30, 2013 11:49 am Up
My Euro Car Parts coil pack came in a Valeo box but it was a Sagem inside!
NayNay1991x
PostPosted: Mon Dec 30, 2013 12:24 pm Up
Will the coil pack have the brand on it?
206 1.4i GLX 1999
PostPosted: Mon Dec 30, 2013 12:27 pm Up
Yes they should do. Mine has it near the connector.
PostPosted: Mon Dec 30, 2013 4:17 pm Up
I'm still running the original Bougicord coilpack (+cap mod) from 2001..
Do you recon I should replace it?
NayNay1991x
PostPosted: Tue Dec 31, 2013 2:07 am Up
Will she run slightly better with a new coilpack?
206 1.4i GLX 1999
PostPosted: Thu Jan 02, 2014 1:42 pm Up
I bet she will..
