Posted: Thu Jan 02, 2014 5:17 pm |
Hi people new to all this, have a question if I may, ive got a 1.6 hdi gti with a faulty oil temperature gauge on the clocks any ideas where to start on how to get it working again, everything else in the car works fine it's just that gauge that doesn't work, i am also on a very tight budget, thanks for your help.in advance
Moved to 206 problems and title edited to get you more responses - Macca1411
Posted: Fri Jan 03, 2014 3:29 am |
Well in this case this problem can be caused by 3 reasons :
1-Faulty Speedo (oil temp gauge),and it can be tested using a PP2000,to make sure it's in full working order or not.
2-Bad wiring for the Oil level sensor,which do jobs here,as an oil leveler,and oil temp. sensor.
3-A Faulty Oil sensor.
so you need to test and see which is the cause.
Posted: Fri Jan 03, 2014 3:36 am |
The oil level sensor seems to be working ok, it registers the oil level fine on start up, what is a pp2000?, can a new sensor be bought from any motor factors?
Posted: Fri Jan 03, 2014 6:39 am |
PP2000 is the diagnostic software ... would allow you to test the gauge and sender works.
You may find one at a motor factors, but probably a dealer is the best bet or internet ...
Think it simply screws into sump. If you jack up the car so oil is tilted away from sender you shouldn't lose any oil.
Posted: Fri Jan 03, 2014 8:21 am |
I have spoken to peugeot they have told me it is situated around by the starter motor and has a long probe on the end of it, they also said it is quite difficult to change by the diy mechanic do you know if this is true
Posted: Fri Jan 03, 2014 11:05 am |
Send me your VIN,and I can check the exact location of the sensor,other wise can't tell if it a DIY job or a mechanic.
Check this link,you might find a close Mechanic from this great forum,who can do it for you.
www.206info.co.uk/Foru...58367.html
also,check this PP2000 Map to see if any member is close to you ,who can help you to know what is really faulty.
www.206info.co.uk/Foru...55053.html
