Online Now [1349]:
Visitors: 1348
Today: 423917
Total: 153819668
Forums › The Car › Request a how-to › Replacing radio, Peugeot 206 HDI, 2004
jeor
PostPosted: Sat Jan 04, 2014 4:50 am Reply with quote Up
Hi forum
Sorry if it had been up before, but I couldn“t find what I need to know.
I have installed a new Pioneer HED-X8500DAB instead of the stock radio.
Now my problem is, that clock, temp and date information in car display is not working proberly.
I belive it has to do with the CAN bus.
Can I disable the connection in the ISO DIN connector or do I have to terminate the bus?
Thanks in advance. Smile
rlees85
PostPosted: Sat Jan 04, 2014 5:40 am Reply with quote Up
I have read resetting the BSI cures it.... if not, how have you wired it up? (Just standard ISO plug and aeriel or stalk controls too or ?)
jeor
PostPosted: Sat Jan 04, 2014 6:09 am Reply with quote Up
I have connected it with the connectors that came with the Pioneer headunit. Swap around the red and yellow wirers.
What do you mean about resetting the BST? Is it disconnecting the batery?
Btw, sorry for my bad english.
AndrewR2211
PostPosted: Sat Jan 04, 2014 7:06 am Reply with quote Up
yes, just disconnect the battery, then reconnect it. I had this problem with my first car, couldn't work out how to fix it, then the battery ran flat one day, after jump starting it worked fine.
My 206 Sport
jeor
PostPosted: Sat Jan 04, 2014 7:46 am Reply with quote Up
Thank you very much Andrew
I will try to disconnect the batery a.s.a.p. Smile
PostPosted: Sat Jan 04, 2014 8:40 am Reply with quote Up
Read how to do it correctly first to reduce the risk of having a costly bill.
Beginners Guide
jeor
PostPosted: Mon Jan 06, 2014 2:34 pm Reply with quote Up
Hi
The problem is solved. Disconnected and reconnected the battery.
Thank you for your assistance Smile
  Quick Reply
Username:
Message:
Quote the last message
