Posted: Sat Jan 04, 2014 10:31 am |
I have a 1.4 petrol. I use the motorway everyday for about 30 mins and go around 65-70mph . The cars temp stays more or less at 80 , maybe a smidge over. Is that normal for these cars in this cold weather as only had it for 3 weeks (also driving with the heater on if that matters ?)
Cheers for any advice
Posted: Sat Jan 04, 2014 10:47 am |
I also have a 1.4 and I can tell you that depending in weather,speed and if you have blower on or off 80-90 is very normal temp.
| why wont you work??????????????????? ARGH F**k it!!!!! | |
Posted: Sat Jan 04, 2014 10:50 am |
I can confirm this. I thought it was weird at first too but the 1.4 runs at 82c at normal running temp. On the motorway at those speeds you will see it run between 80 and 90 very easily but normally never above 90.
Yours is running fine
Posted: Sat Jan 04, 2014 11:05 am |
Cheers, thought it seemed a tad low but as long as that's normal/common then all good !
Posted: Sat Jan 04, 2014 2:52 pm |
Usually because of the motorway speeds alot more airflow is getting into the bonnet so you would see lower temps than running around in town for 30 minutes.
| I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport | |
Posted: Sat Jan 04, 2014 3:29 pm |
100% normal for these. It took me ages to get used to this temp reading.
Posted: Sat Jan 04, 2014 4:08 pm |
Well,guys...what is the use of a Thermostat then!!???
Posted: Mon Jan 06, 2014 2:15 pm |
My daughters 1.4LX ran at just over 80°. In town or left to idle for a long time it would slowly creep to 90° at which point the fan would would kick in and drop it back to 80°. That was after a new thermostat was fitted because prior to that it would run at 70° or lower. Also changing the thermostat improved mpg from about 28 to 32mpg.
I consider what Docbooze describes as normal.
IIRC the new thermostat was marked at 82°.
