Online Now [1195]:
Visitors: 1194
Today: 328325
Total: 151446207
Forums › The Car › 206 Problems › Random cable going from Engine fuse box to LED on Dashboard
MrRichmond1995
PostPosted: Tue Jan 07, 2014 12:32 pm Up
Hello Guys!
I whilst installing the power cables for my two Amps I noticed that there was a random cable going from my engine fuse box to a LED next to the Lock and Hazard Light button on my dashboard.
Below is a photo of the cable in the fuse box, my key is being used to show which cable it is that has been spliced into.
I was wondering if anyone knew why the previous owner might of installed it into my car and if so what the LED would possibly indicate?
My car is a 2005 206 Zest 3 1.4L
Thanks in advance!
Nissan Pulsar C13 Owners Club
Mod List:
Lowered 30mm
HEL Braided Brake Lines
EMP Backbox Delete
Full Custom Audio Build
Full LED Light Conversion
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Tue Jan 07, 2014 12:43 pm Up
Looks original to me with the writing on the insulation. What's under that tape?
MrRichmond1995
PostPosted: Tue Jan 07, 2014 12:46 pm Up
Hey Edward
The tape is there to cover the soldiering from shorting out.
The cable runs through the firewall grommet up to my dashboard which covers the MFD, It turns off when I turn the car off and then goes out about 30 seconds after the key is removed, It doesnt always light up and is rather confusing!
I'm going to the Shops later so I will get a picture of the LED and wiring near the MFD then.
Just looking in my Haynes manual to see if it can tell me what that wire is responsible for.
Mod List:
Lowered 30mm
EMP Backbox Delete
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Tue Jan 07, 2014 12:56 pm Up
If there's writing on the insulation, see if you can find a number on it, will be your best bet at finding a corresponding number on a wiring diagram.
MrRichmond1995
PostPosted: Tue Jan 07, 2014 12:58 pm Up
Okie dokie.
Ill take a look and pictures when I go out to the shops
Cheers
Mod List:
Lowered 30mm
EMP Backbox Delete
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Tue Jan 07, 2014 1:32 pm Up
How do you know that cable is feeding the LED?
MrRichmond1995
PostPosted: Tue Jan 07, 2014 1:39 pm Up
Because the cable runs through the grommet and goes up to the MFD where the LED is connected to it.
Mod List:
Lowered 30mm
EMP Backbox Delete
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Tue Jan 07, 2014 1:44 pm Up
Someone may have put a flashing LED in to give the impression that an alarm is active. That's probably where they thought was the best place to get a constant live not realising that the car goes into ECO mode to save the battery from being drained.
MrRichmond1995
PostPosted: Tue Jan 07, 2014 3:06 pm Up
Spot on Macca!
My parents car has just come back from having its MOT done (Failed, Seat mount was cracked) and our friend who also used to be a Peugeot Master Technician before he moved to Citroen said who ever put it in obviously tried to fit a Flashing LED for a fake alarm and didn't wire it correctly and must of given up fixing it!
Mod List:
Lowered 30mm
EMP Backbox Delete
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
AJAC
PostPosted: Tue Jun 21, 2016 4:03 pm Up
Well if you looked. I think you would have found 2 whitish wires connecting to a single thick yellow wire
MrRichmond1995
PostPosted: Wed Jun 22, 2016 5:12 pm Up
Yes I can see that. The post is Nearly three years old now and the car is now scrapped
Mod List:
Lowered 30mm
EMP Backbox Delete
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
