Latest: sparrowdclxvi
Overall: 17139
Online Now [119]:
Visitors: 118
Today: 12186
Total: 113580473
Forums › The Car › 206 Talk › Engine Code
Engine Code
jamie-38-206
PostPosted: Sun Dec 29, 2013 4:58 pm Up
Hi,
I was looking at service parts on Euro Car Parts but when i type in my reg it gives me the option for 2 different engine codes. I looked at my V5 and it says my engine code is
KFW
but euro car parts gives 2 engine codes. KFW(TU3JP) and KFW(TU3A)
my car is a 206 1.4 2004
many thanks
PostPosted: Mon Dec 30, 2013 5:13 am Up
ECP isn't that accurate when using the reg. It lists mine as having ABS and air conditioning.
KFW is the code for it being a 1.4 8v built to EEC standards in whatever year. Pretty sure the A or JP is a PSA code for fuelling and power levels.
I've had 3 KFWs sat outside all at the same time. The 2003 is a TU3JP and the 2006 is a TU3A and a TU3JP lump in a 2001 Xsara. All look exactly the same and delivered the same power from the factory. From looking at them, there is no difference, but if you went into detail there would be something minute somewhere.
PM me the last 8 of your VIN and I'll check on Peugeot Servicebox for you to see what's fitted.
jamie-38-206
PostPosted: Mon Dec 30, 2013 5:52 am Up
Hi ,
KFW(tu3jp) and KFW(tu3a)
From my VIN I only see the KFW part. what is the part in brackets?
PostPosted: Mon Dec 30, 2013 1:28 pm Up
Yours will be a tu3a. The jp is the older version
PostPosted: Mon Dec 30, 2013 3:55 pm Up
It's listed as a TU3JP on servicebox.
206 3 DOOR SALOON 1.4i 75 (TU3JP) Manual gearbox 5
Warranty start date 9/2004
PostPosted: Mon Dec 30, 2013 5:17 pm Up
Now that does suprise me!
Ah well they are close enough
PostPosted: Thu Jan 02, 2014 2:46 pm Up
The TUA setup is basicaly motorised throttlebody, different ECU, some other differences in brakes etc. Used on some 207 as well, it was introduced sometime in 2007 I believe. I don't know if the engines themselves are different.
standardgt180
PostPosted: Wed Jan 08, 2014 8:59 am Up
anyone have a idea how to find out the gearbox code please ?
PostPosted: Wed Jan 08, 2014 10:41 am Up
Taken from the VIN number you sent about the engine code
Gearbox Transmission
TRANSMISSION BVM5
GEARBOX (CHARACTERISTICS) BVM MA5 / N
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 16 X 65
SPEEDOMETER DRIVE TACHO TORQUE 19X17
WHEEL STYLE 14 INCH STEEL WHEEL
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
GEARBOX TYPE (TYPE APPROVAL) GEARBOX MA/5 N TYPE
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 68
TYRE (SIZE, TYPE) PNEU 175/65 R14 82T NON RENFORCE
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE MA
PostPosted: Fri Jan 10, 2014 7:51 am Up
Bear in-mind there is an update version at some point in MA boxes which makes them incompatible with previolus engine crankshaft ends or whatever.
