Latest: Puggingalong
Overall: 17129
Online Now [59]:
Visitors: 58
Today: 51797
Total: 100721140
Forums › The Car › 206 Problems › Cabin fan stuck on max
Zitron
PostPosted: Tue Jan 07, 2014 9:05 am Up
Got a 2003 GTI with digital CC. The fan is stuck on max speed and the only thing I'm able to adjust is temperature (luckily). Turning the fan speed down does nothing and even turning off completely doesn't work. The display updates correctly when pressing buttons but nothing happens.
Any ideas? Cheers.
iainlovatt
PostPosted: Tue Jan 07, 2014 9:10 am Up
Could try a new heater control. Is the button stuck or jammed in??
(My Garage)
Zitron
PostPosted: Tue Jan 07, 2014 9:17 am Up
That was gonna be my first thing to try. Nah doesn't look like it. As I said I can turn it off, display goes off and the fan will still be going. Laughing
dannyboy-gti
PostPosted: Tue Jan 07, 2014 1:56 pm Up
That's the resistor gone faulty most probably. On models with climate it's part of the fan. You have to remove the fan to change the resistor within it. The fan comes out like any other 206 fan, by removing the glovebox. Cheapest fix is a second hand fan unit off eBay and swap as a whole, otherwise new resistor is about 60 last time I looked. You need the fan with 2 connectors for the climate model, not the fan with one. Part is shared with other pugs and also some Citroens.
If you search the forum you'll find my old thread, and some others about it.
30 min job to swap.
Zitron
PostPosted: Wed Jan 08, 2014 12:51 pm Up
30 min job to swap.
Nice one. Thanks for that, will take a look for that thread.
DREWDEN
PostPosted: Wed Jan 08, 2014 4:32 pm Up
BSI reset maybe.
206 2ltr Hdi glx 53 plate
Zitron
PostPosted: Thu Jan 09, 2014 5:41 am Up
DREWDEN wrote:
BSI reset maybe.
That's a good shout as I haven't actually tried that yet. Worth a shot. Cheers.
DREWDEN
PostPosted: Fri Jan 10, 2014 8:41 am Up
Did the bsi reset achieve anything.
Zitron
PostPosted: Sun Jan 12, 2014 5:25 am Up
Nah no luck unfortunately. Looks like I'll order a new blower. Was worth a go though.
DREWDEN
PostPosted: Sun Jan 12, 2014 9:59 am Up
Whilst you are waiting to replace the blower unit, i would reccomend you isolate the power supply to the blower, the electrical system takes a lot of battering to the blower, as in my case the 40amp fuse had welded itself in the holder and not actually blown it. you can remove the 40amp Air Conditioning Fan, fuse 18 in the engine fuse box (bottom right).
You could also then remove the blower unit itself, once removed clean the two connectors going into the motor and out of the motor (2 pin) and (5 pin) especially the 5 pin which operates the speeds of the fan, these have a tendancy for going black and resulting in a bad connection.
Then possibly try the motor again after cleaning the connectors.
Zitron
PostPosted: Mon Jan 13, 2014 8:01 am Up
Brilliant, thanks for that. Cool
Zitron
PostPosted: Thu Jan 16, 2014 9:28 am Up
Well it was the blower. New one turned up today unfortunately all the plastic retaining clips were cracked off and the fan was cracked in one spot. Fitted it anyway but made a racket on full speed so getting a new one sent out, probably be monday now though Sad At least I know it's that I guess. Christ it was a pain to twist the old out Mad Now to fix the problem with my clutch Laughing Neverending story.
Cheers lads for the help.
DREWDEN
PostPosted: Thu Jan 16, 2014 10:16 am Up
The fan fins should have 1 or 2 tiny metal clips, that balance the fan, so when the fan is at a fast speed it is running true and not make any noise, pretty much like when a tyre is ballanced.
Check when it arrives, then when fitting you don't knock any off.
Are tested at manufacturers before dispatch.
Good news all is well.
dannyboy-gti
PostPosted: Thu Jan 16, 2014 1:00 pm Up
Seeing as your old fan and motor still work you can just swap the resistor from the damaged fan and then you've got a whole spare unit to sell or keep!
