Forums › The Car › 206 Problems › strange overheating problem 206 1.4 |
Posted: Wed Oct 16, 2013 2:10 pm |
Hi,i dont know where the fan plug is (if thats what its called) to do the bypass test straight to the battery,realy dont know much about it and no diagnostic machine,took the heat sensor off and the temp went into red and stop sign was on but no fan came on at all nor the aircon,i dont want to get ripped of because iam a woman so trying to fix it myself.. lol is it the plug that goes into the resistor?
Posted: Thu Oct 17, 2013 3:37 am |
onAny info would be great thanks.
Posted: Thu Jan 09, 2014 12:01 pm |
fan problem solved,it was the wires going to the relays corroded,replaced the wire with small connectors and new wire all sorted
