Latest: Andyblue64
Overall: 17123
Online Now [156]:
Visitors: 155
Today: 905
Total: 98088188
Forums › The Car › 206 Talk › Just bought my first 206 today
SLI09144416
PostPosted: Fri Jan 10, 2014 1:39 pm Up
As the owner of a 1993 106 for more than five years, I thought it was finally time to upgrade. And what better time with my neighbor selling his son's 206 at a steal of £150!
Little did he tell me however, that it requires £600 worth of welding.
So, whilst money isn't the biggest issue in this, do you think it's worth it? I'll attach the MOT here for you to look at, but I would appreciate any advice/guidance/etc.
Many thanks!
PostPosted: Fri Jan 10, 2014 2:49 pm Up
Welcome to the 206info mate,this is cheap,but might be expensive to work on,any pics of it?
SLI09144416
PostPosted: Fri Jan 10, 2014 2:50 pm Up
REMOVED
SLI09144416
PostPosted: Fri Jan 10, 2014 2:51 pm Up
Here's the MOT mate
PostPosted: Fri Jan 10, 2014 2:55 pm Up
I'd love to see some pictures of the corrosion. It's quite unusual for a 206 to be like that.
SLI09144416
PostPosted: Fri Jan 10, 2014 2:57 pm Up
Anyone any ideas of whether it's worth doing?
ukskater01
PostPosted: Fri Jan 10, 2014 3:01 pm Up
Well it will need new brake lines with a new brake bias valve. Then a lot of welding. You will need a bodyshop to take a loook and give you a quote. It doesn't sound that bad
2Oh!6
PostPosted: Fri Jan 10, 2014 3:10 pm Up
1999 with 105k on the clock, wouldn't bother tbh you could get a much better example with alot less hassle and money overall.
VTEC goes BWAAAAAAH! Wink
PostPosted: Fri Jan 10, 2014 3:32 pm Up
well total cost will be 150+600 GBP=750 GBP more or less,so I would say don't bother,and buy a decent car for 1000 GBP instead
Seatock789
PostPosted: Fri Jan 10, 2014 3:40 pm Up
I agree with Timon2210, Get something decent with less mileage on and in better condition, sounds like a bit of a death trap. Who knows what else he hasn't told you about, remember the MOT doesn't pick up every fault so it may end up costing you a lot more.
PostPosted: Fri Jan 10, 2014 4:38 pm Up
Can't understand how it could be that badly corroded. Has he been driving it in the sea?!
commandosqueak
PostPosted: Fri Jan 10, 2014 7:17 pm Up
get some pics up of all this corrosion etc and we can see how bad it really is. then we can give more taylored advice rather than general. the mot makes it sound dreadful but as somebody has always said 206's don corrode like that normally.
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
PostPosted: Fri Jan 10, 2014 11:03 pm Up
As Edward says, any pictures of all this corrosion? I've never seen or heard of anything that bad before. Confused As for the rest, it's simple fixes.
And as the original question goes, what's the bodywork and interior like?
SLI09144416
PostPosted: Sat Jan 11, 2014 11:36 am Up
I've uploaded some photos online, but there's too many to add here so please feel free to browse the folder:
[REMOVED OUTDATED LINKS]
DSWR
PostPosted: Sat Jan 11, 2014 12:40 pm Up
with all the work that needs doing, it's probably going to be cheaper for you to just buy another peugeot. You can get some right crackers for 750 odd, really are a steal.. 105k miles is a lot, and it's pretty damn old. I've got a friend with a 1999 peugeot 206, mint, nothing wrong, 46k miles, worth about £900, so just worth looking around for another motor, Pal.
GTi 180 owner!:)
www.facebook.com/notdanwhite
