![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › Just bought my first 206 today |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Sat Jan 11, 2014 12:52 pm |
There are no picture on there of the MOT failure areas.
| | ![](images/spacer.gif) |
Posted: Sat Jan 11, 2014 1:39 pm |
I wasn't able to get to any of them, and I didn't know where they were!
Posted: Sat Jan 11, 2014 8:38 pm |
Nevermind, my Dad showed me! See attached:
[REMOVED OUTDATED LINKS]
Posted: Sun Jan 12, 2014 9:53 am |
I thought 206's weren't bad in terms of rusting? That MOT form just looks like my saxo, sold it on eBay for £200 was about £700 worth of work. Although I did need a new rear beam.
That Widespread corrosion sounds a bit worrying...
Posted: Fri Jan 24, 2014 5:57 pm |
I have now decided to have the work done, I've sold my old 106 for £450 which should pay the majority of the work being done. It's a good little car, and once the corrosion's sorted it should last a good 5/6 years.
| ![](themes/base/images/forums/otr.gif) |
