Forums › The Car › 206 Talk › Weight of an air conditioning unit |
Posted: Sun Jan 12, 2014 1:39 pm |
Does anyone know how much an air conditioning unit weighs including any pipe work.. was thinking of removing it if its heavy. I cant see it being really heavy, but I am stripping the interior.. seats etc so was thinking to get rid of that as well.
Posted: Sun Jan 12, 2014 2:20 pm |
This lot weighs 10kg. I anybody tells you anything else they are wrong. I weighed it myself.
Posted: Sun Jan 12, 2014 2:48 pm |
Thanks Edward did you take it out for weight reduction or did it get in the way of a mod you have done?? I know its only 10kg but it all adds up doesnt it and its not like we are in tenerife and seriously need air-con so out it comes
| 1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170 | |
Posted: Sun Jan 12, 2014 2:52 pm |
I just took it out because I wanted anything unnecessary out of the engine bay.
10kg is almost 1% of the overall car weight.
Posted: Sun Jan 12, 2014 2:57 pm |
Posted: Sun Jan 12, 2014 3:28 pm |
Why was the a hose in your car?!
Posted: Sun Jan 12, 2014 3:34 pm |
Steve206 wrote: |
Why was the a hose in your car?! |
Posted: Sun Jan 12, 2014 3:36 pm |
Edward wrote: |
10kg is almost 1% of the overall car weight. |
Yeah 1 percent is one percent it all adds up
