Online Now [299]:
Visitors: 298
Today: 174622
Total: 155467374
Forums › The Car › Request a how-to › Brake Bleeding 180
Brake Bleeding 180
Go to page Previous  1, 2
Lecktorious
PostPosted: Sat Jan 11, 2014 1:57 pm Reply with quote Up
Trade Rating: +59
bashyy1 wrote:
Okay thanks mate
I'd like to fix it myself really, I just have a hard time deciding what things to check/change first.
When I rub my fingers over the rear discs they don't feel smooth like the fronts do. It's like a very slight bumpy/rough texture. Does that mean they need replacing?
The rear brakes do hardly any work so I wouldn't bother unless they are excessively corroded or pitted and your MOT is soon.
Still sounds like you have air in the system somewhere, I'd rule that out first before starting on anything else.
'98 Nile Blue 306 GTi 6
Conners300983
PostPosted: Sat Jan 11, 2014 2:13 pm Reply with quote Up
At a guess yes, can you post a picture?
bashyy1
PostPosted: Mon Jan 13, 2014 1:38 pm Reply with quote Up
I'd like to try bleeding the brakes as first port of call but that means buying PP2000 at around £100. I think it's silly you need software just to bleed the brake system, surely it's possible to do it without?
I can get a picture of the rear discs if you want yeah.
Aegean Blue Gti 180.
Project Thread
Conners300983
PostPosted: Mon Jan 13, 2014 2:07 pm Reply with quote Up
Gunsons eezibleed clicky
Get yourself one of these, I'm'm 99.9% sure this will work without the software, make sure you buy a bottle of brake fluid with it as you'll need to keep the level topped up or you'll create more problems. There's instructions in the box and I'm sure if you shop about you'll pick it up a bit cheaper
bashyy1
PostPosted: Mon Jan 13, 2014 2:16 pm Reply with quote Up
Heres a pic of the disc anyways, if anyone can confirm they need changing:
I can try it, but can someone tell me WHY exactly you need the software if you do, I'm dealing with brakes so I can't get this wrong.
Also can't I just re-fil it with the fluid I've taken out or does it need to be new?
Project Thread
broadblaster
PostPosted: Mon Jan 13, 2014 2:30 pm Reply with quote Up
pads look ok but discs seem to be getting down (quite a lip on outer edge).
DO NOT reuse the old fluid allway use new (it should be changed every 2 yrs anyway)
you need the software to actervate the abs pump so it purges all the air out of the system.
on a back road playing
PostPosted: Mon Jan 13, 2014 2:41 pm Reply with quote Up
Only if you let air in! The abs pump is closed for bleeding, unless you use pp to open it. It can be done without it.
bashyy1
PostPosted: Mon Jan 13, 2014 2:52 pm Reply with quote Up
Okay thanks for that guys.
Steve do you mean "It CAN'T be done without?"
Project Thread
gtijames22
PostPosted: Mon Jan 13, 2014 4:15 pm Reply with quote Up
What He Said
GTI 180 JIM
206gt160
PostPosted: Mon Jan 13, 2014 4:53 pm Reply with quote Up
I bleed the breaks on my 206 gti all the time and have never once used pp2000. Just use the ezi bleed kit £20 connect that to the brake filler bottle and also a spare tyre with around 15-20 psi. Fill the ezi bleed up with brake fluid. Once you have done this go to the rear r/h brake bleed nipple and connect a bleed tube. Then unscrew the bleed nipple. Wait till the fluid is running air bubble free then tighten the nipple. Top up the ezi bleed with more brake fluid and then do the same with rear l/h, front r/h and front l/h in that order. Making sure to top up the ezi bleed between each brake.
Never once used pp2000
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Page 2 of 2
  Quick Reply
Username:
Message:
Quote the last message
