Latest: sparrowdclxvi
Overall: 17139
Online Now [114]:
Visitors: 113
Today: 28591
Total: 113228574
Forums › The Car › 206 Talk › How wide spacers on flat head bolts
robb
PostPosted: Wed Jan 15, 2014 3:02 pm Up
Just wondering if anyone knows what size spacers can safely be used with standard length factory flat head bolts and 307 challenger alloys?
Im guessing 12mm is pushing it way too much with standard length bolts?
For the rears I will be using 20-25mm hopefully as long as they will fit, with the type of spacers that bolt to the hub, then the wheels bolt to te new spacers, but for the fronts I don't want to go anywhere near as wide so was trying to get away with some hubcentric spacers, Ideally I would like the push the front alloys out at least 9mm to make them out as far as vortex alloys would be.
DSWR
PostPosted: Wed Jan 15, 2014 5:11 pm Up
I'm only using 5mm and thought it was a bit iffy, 7mm max I'd say.
GTi 180 owner!:)
www.facebook.com/notdanwhite
