Posted: Fri Jan 17, 2014 6:18 am |
I have a problem with my 206 cc, i recently had a problem with the heaters/Air con. I checked the fuses but there all ok, now the indicators, electric windows, roof are not working but the radio, lighter, hazards and central locking are working!! What could it be?
Posted: Fri Jan 17, 2014 6:21 am |
Posted: Fri Jan 17, 2014 6:28 am |
Thanks, but i cant get through the windows as the windows don't work to do the full reset.
Posted: Fri Jan 17, 2014 6:36 am |
Wezland wrote: |
Thanks, but i cant get through the windows as the windows don't work to do the full reset. |
Connect a battery to the window motor, and you should be able to operate it with the window switch
Posted: Fri Jan 17, 2014 6:50 am |
I haven't a clue about cars, how do i do that? Sorry
Posted: Fri Jan 17, 2014 7:23 am |
Get a friend/partner to sit in the car while you connect the battery and then ask them to turn the sidelights on when you tell them. Done that quite a few times when the battery has been off overnight.
