Latest: Worthy967
Overall: 17143
Online Now [174]:
Visitors: 173
Today: 12765
Total: 115844185
Forums › The Car › 206 Problems › Peugeot 206 engine cut out!!! please post your problems!!
Go to page Previous  1, 2, 3
Does your peugeot 206 keep cutting out???
Yes
32%
 32%  [ 14 ]
Occasionally
13%
 13%  [ 6 ]
Never
53%
 53%  [ 23 ]
Total Votes : 43
discojohnny69
PostPosted: Wed Sep 18, 2013 4:15 am Up
i have the same fault with my car been from garage to garage but no good they say there is no fault but it is still the same cuts out been told it could be the ecu but not sure its been on diagnostics the lot but still no good
Paddy1795
PostPosted: Wed Sep 18, 2013 6:51 am Up
My car suffers from a similar problem, no fault codes, fluid levels all correct and new spark plugs recently. Looking for a new car.
PostPosted: Wed Sep 18, 2013 9:49 am Up
Try looking for a mechanic that knows what there doing Rolling Eyes
Paddy1795
PostPosted: Wed Sep 18, 2013 11:06 am Up
If I'm honest, the cars not worth the money.
greenpug2222
PostPosted: Thu Sep 26, 2013 12:56 pm Up
Mine has just started doing this (cutting out) .
Does anyone know what the fixes were from Peugeot?
why wont you work??????????????????? ARGH F**k it!!!!!
DREWDEN
PostPosted: Thu Sep 26, 2013 1:30 pm Up
Anyone see watchdog last night.
Why don't all you people out there with the problem start a tweet.
Loved the way the famous actor, fought the car giants for his daughter.
206 2ltr Hdi glx 53 plate
Lwaznax
PostPosted: Fri Sep 27, 2013 6:03 am Up
My 206 has been doing this for a couple of weeks now, i sent to Peugeot dealer and they told me i need to change the catalytic converter and oxygen sensors. Which just costed me R12K (1200pounds), and on my way to work, it still cut off. I am in the dark and thinking of looking for a new car because this is just not on.
From what i have been reading on the internet, it could be alot of things. i.e Spark plugs, ECU etc. Like seriously don't have money to waste on fixing things that are probably not even faulty or broken in this car. I am at a loss!
thesigma3
PostPosted: Fri Sep 27, 2013 4:33 pm Up
clean the throttle body, follow the how to in the how to section, this fixed my cutting out issue immediatly!
stu861
PostPosted: Sat Jan 18, 2014 3:31 pm Up
Did anyone figure this out as my car is doing this also only at low speeds and all the dash lights come on at the same time ? Before I brought it it had a service anything I should check??
PostPosted: Sat Jan 18, 2014 3:57 pm Up
Check the earth lead from the battery to the gearbox
Page 3 of 3
