Latest: elelectricistadeMateo
Overall: 17127
Online Now [69]:
Visitors: 68
Today: 1083
Total: 100399321
Forums › The Car › 206 Problems › Electronic throttle pedal 2005 1.4 206, Part Numbers?
Nellie
PostPosted: Wed Jan 22, 2014 5:39 am Up
Hi,
I am looking for a replacement electronic throttle pedal for my 2005 206, 1.4 Verve.
There are lots on ebay that are the same style and with the correct number of pins in the wiring connector, but the numbers on mine are not exactly the same.
Does it have to match exactly or will the same design from another Peugeot do the correct job?
I only ask because sometimes the same parts are used on several cars,
Thanks in advance
Neil
Neil C
PostPosted: Wed Jan 22, 2014 6:09 am Up
Listed on servicebox
1601N1 - 4 VOIES - PEDAL STANDARD UNTIL RPO 10800
1601X6 - 5 VOIES - PEDAL STANDARD SINCE RPO 10801
1601P0 - 4 VOIES - PEDAL ALUMINIUM UNTIL RPO 10800
1601X7 - 5 VOIES - PEDAL ALUMINIUM SINCE RPO 10801
Not sure what the VOIES are as they translate to tracts. That could be the number of grooves on the grip or the number of pins in the connector. Should be able to narrow it down better with the VIN
PostPosted: Wed Jan 22, 2014 6:19 am Up
Number of 'ways' so pins on the connector.
I have a pedal for RHD but have to check number of pins if you want it..
PostPosted: Wed Jan 22, 2014 7:31 am Up
Thumb Up
And V, I'm waiting on an email on that other problem and then I'll forward it on to you.
Nellie
PostPosted: Wed Jan 22, 2014 8:18 am Up
OK thanks, For the time being I've got one from my local breaker with the same number of wires.
Just fitted it, going to give it a couple of days to adjust the setting and see what happens.
Neil
Neil C
PostPosted: Wed Jan 22, 2014 3:36 pm Up
You'll want to at least disconnect and re-connect the battery at this point!
Following the correct procedure for re-connection etc.
