Latest: Andyblue64
Overall: 17123
Online Now [490]:
Visitors: 489
Today: 126639
Total: 98495324
Forums › The Car › 206 Problems › Car cutting out
Car cutting out
Mlachhab
PostPosted: Wed Jan 22, 2014 8:30 am Up
Hi all,
I bought my car around 4 months ago, however in the past week or so every morning (8AM) I would drive off and as soon as I put the clutch in (dropping the revs below 1K) the car would cut out. However once I restarted the car it would be totally fine. In the last two days the car has struggled to start and needed assistance with some acceleration to get started. Again, once started if it would drop below 1K revs the car would cut out and this morning on my drive to work it must've happened around 10 times! It's also not the best when your power steering cuts out too! Once the car was totally warmed up, around 30 mins into my journey the car was fine.
Anybody had anything similar? I've read on similar threads that this sounds like the temperature sensor?
Thanks,
Mlachhab
PostPosted: Wed Jan 22, 2014 8:32 am Up
I've got a 206 1.4LX 2001
Cheers
webbo_23
PostPosted: Wed Jan 22, 2014 8:36 am Up
I had this problem....i just took the idle control valve out, cleaned it all up, but it back together and it worked fine
20Drift
PostPosted: Wed Jan 22, 2014 8:44 am Up
What He Said
www.206info.co.uk/Foru...+body.html
Mlachhab
PostPosted: Wed Jan 22, 2014 10:54 am Up
20Drift wrote:
Cheers Guys! Il'l give it a bash later on!
