Online Now [313]:
Visitors: 311
Members: 1
Today: 53752
Total: 157718421
Forums › The Car › Solved 206 Problems › Possible broken button
Forum Index › Solved 206 Problems
astra_aurelis
PostPosted: Wed Jan 22, 2014 11:11 am Up
Does anyone know how to work out if the button on the windscreen wiper stalk is broken?!
I'm trying to change the display unit to show how many miles I have left in my tank. I kindly jump started a car, it reset my battery and now this info isn't showing on the display.
PostPosted: Wed Jan 22, 2014 12:13 pm Up
Not sure if you can pop it off with a small screw driver and then use a cocktail stick to see if the switch is working.
Have you tried doing a soft boot on the BSI?
Beginners guide
astra_aurelis
PostPosted: Wed Jan 22, 2014 4:43 pm Up
Yeah I tried that earlier but it didn't seem to make a difference. I will try that but I don't want to break anything!!!
commandosqueak
PostPosted: Thu Jan 23, 2014 3:49 am Up
i didnt think you could jump a 206 cause of the bsi system? all i can suggest is a soft reboot
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
astra_aurelis
PostPosted: Thu Jan 23, 2014 4:54 am Up
You can jump start a car with another which has a bsi system, you just have to be a bit careful how you do it.
astra_aurelis
PostPosted: Fri Jan 24, 2014 10:54 am Up
So I managed to fix it. I just took the end off the button, used a small screw driver to clean it out and removed some weird orange stuff from it, put the button back on and IT WORKS!!
PostPosted: Fri Jan 24, 2014 11:15 am Up
Thumbs Up
