Latest: DanDan17
Overall: 17128
Online Now [110]:
Visitors: 109
Today: 23284
Total: 100543197
Forums › The Car › 206 Problems › Temperature gauge stuck at 90 when car not running
wildcat01
PostPosted: Mon Jan 27, 2014 10:15 am Up
Hi, I bought a Peugeot 206 1.4 '02 automatic recently, the temp gauge is stuck half way when the car is not running & flickers, jumps to red as soon as car is started & fan kicks in soon as. I have just paid £600 at a garage to fix it but still is the same, it's had new thermostat, temp switch & other things but now been told that it could be a fault with the ecu, could anyone help this damsel in distress please Crying or Very sad
mattymj
PostPosted: Mon Jan 27, 2014 10:32 am Up
Was it the coolant temperature sensor they changed?
wildcat01
PostPosted: Mon Jan 27, 2014 10:34 am Up
Hi, all I know is it's the green sensor next to the blue 1 & on my bill it just says temp switch ?
mattymj
PostPosted: Mon Jan 27, 2014 10:37 am Up
A quick scan of the ecu should show the fault.
Where are you based?
wildcat01
PostPosted: Mon Jan 27, 2014 10:41 am Up
I'm Sheffield & the garage said they had an auto electrician test it & it showed a fault on the ecu but got no codes for me I feel I'm being ripped off & just told this to take my car back to them at more cost to me ?
wildcat01
PostPosted: Mon Jan 27, 2014 10:43 am Up
I've been reading the threads & some say there are 3 sensors others say 2 & also could be a dash wiring or sensor fault
mattymj
PostPosted: Mon Jan 27, 2014 11:05 am Up
Check on the Pp2000 map. There maybe a member nearby who can offer assistance. There are some dodgy garages out there
mattymj
PostPosted: Mon Jan 27, 2014 11:11 am Up
Link
Web Page Name
wildcat01
PostPosted: Mon Jan 27, 2014 11:18 am Up
Thanks for your help & replies I'm new to this & blonde Smile
mattymj
PostPosted: Mon Jan 27, 2014 11:53 am Up
Well thats no excuse for a garage ripping you off
PostPosted: Mon Jan 27, 2014 7:36 pm Up
Not necessarily.
'Bit more detail needed and history of the problem, esp if a professional garage has already worked on it.
