Online Now [525]:
Visitors: 524
Today: 109536
Total: 156462008
Forums › The Car › 206 Talk › Worn Droplinks
Worn Droplinks
Forum Index › 206 Talk
PostPosted: Wed Jan 29, 2014 3:23 pm Up
From the service beginning of november it was highlighted that the n/s droplink was worn but have yet to replace it, how long can I go for before it causes other damage? Got my mot end of feb so was thinking of getting it done then as it's been 3 months already almost
PostPosted: Wed Jan 29, 2014 3:28 pm Up
If its badly worn it will more than likely fail mot. It wouldn't cause much in the way of damage, but better to get it seen to sooner rather than later. Motor factors are usually around the £10 mark + vat, and its only 2 bolts to undo. Just sometimes you need a grinder to take the old one off. Garage shouldn't charge you more than half hour labour for it.
123nathan0g
PostPosted: Wed Jan 29, 2014 3:31 pm Up
as far as damage goes I wouldn't think of that as such, when it gets to the point of knocking over speed bumps is when id change them, more to the point of the knocking will get annoying, if your confident its a ten min job to do your self, either source the parts from ebay or somewhere like euro car parts etc, take the wheel off and there right there, bit of wd40/ penetrating fluid to loosen them up, and a socket the right size, either 15,16 or 17? if your lucky they will have a spanner on the back, if not use mole grips, as there getting replaced, I wouldn't worry about damaging them Smile
PostPosted: Wed Jan 29, 2014 3:49 pm Up
16mm ratchet spanner and torx bit...that's all they need.
PostPosted: Wed Jan 29, 2014 4:04 pm Up
When they want to be nice, then yes, everyone ive done ive had to grind off.
AndrewR2211
PostPosted: Thu Jan 30, 2014 12:56 pm Up
Yea f*** that, grinder and cut them off, saves a lot or fafing time
My 206 Sport
usher
PostPosted: Thu Jan 30, 2014 1:09 pm Up
my advisory drop link lasted over 3 years and still didnt fail when it was replaced, i would change it when it starts to knock
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Goldin
PostPosted: Thu Jan 30, 2014 5:32 pm Up
I changed them a few days ago because the knocking was very annoying.
Now it's pleasure to drive in quiet over small bumps Smile
southwestchap
PostPosted: Fri Jan 31, 2014 5:17 am Up
See this before.
PostPosted: Fri Jan 31, 2014 9:38 am Up
Great stuff. If somebody is willing to bodge something so cheap I hate to think what the rest of the car is like.
DanT
PostPosted: Fri Jan 31, 2014 9:48 am Up
Lot of very low cars run cut & welded drop links if no-one makes proper shortened ones to fit.
However the picture above doesnt appear to be for that reason lol. I dont understand why you wouldnt just use new ones they hardly cost the earth.
