Posted: Thu Jan 30, 2014 9:11 am |
Hi guys ,
Im wiring a single strip LED in my left footwell , ive stuck the LED on the underside of the glove comparntment and ive ran a short amount of wire back into MY ASH TRAY below where the little ash tray is im guessing these are NEG & POS , so the lights will come on when side lights and headlights on but i dont want that does anyone know what sort of with i need to control as when my lights stay on i can switch my LED's on/off due to it being to bright whilst driving and draining battery ? Im guessing its a 2 way switch just power out from the ashtray light into my switch and the wire out to my LED's.
Thanks guys
Posted: Thu Jan 30, 2014 9:12 am |
***Anyone know what sort of switch***
Posted: Thu Jan 30, 2014 9:19 am |
spst switch with a inline fuse wired into the cig lighter would be fine. just make sure you do the connections properly and take the battery off first!!!!!!
| 2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey | |
Posted: Thu Jan 30, 2014 9:33 am |
Okay thanks pal , can i not just wire it off the ashtray light through a rocker switch or not ?
Posted: Thu Jan 30, 2014 9:45 am |
yeah you can do. as long as you have a 12v dc positive and negative then all is good. just make sure the LED's are wired the correct way round as they are polarity sensitive.
Posted: Thu Jan 30, 2014 9:57 am |
Yeah mate just bought a simple 2 spade connector 12v rocker switch , and yeah matw i will do just been messing about just testing things. Alls good thanks for the help.
