Online Now [886]:
Visitors: 885
Today: 127786
Total: 157433305
Forums › Tuning, Modification & Legal › Project Cars › ushers track project fully stripped and trimmed
Go to page Previous  1, 2, 3 ... 11, 12, 13 ... 16, 17, 18  Next
usher
PostPosted: Sun Feb 02, 2014 1:03 pm Up
yeah i have re done one wire which made the fan come on but then stopped, couldnt say wether it was fast or slow as it was that quick. the car got in to the red on water temp, oil temp didnt move, the rad was hot so assume the water is pumping round right
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sun Feb 02, 2014 1:05 pm Up
Check the fuses first and then perhaps try a new fan relay. I would go with Eds idea and stick with full speed only. Less to go wrong in the future
usher
PostPosted: Sun Feb 02, 2014 1:08 pm Up
can i not run it with a live and remove the relays all together and run it from another source ie thermostat
fuses all seem fine but wiring not 100% as some functions dont work how they used to and some interfeer with others
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sun Feb 02, 2014 1:17 pm Up
You need a relay to take the current. If you go direct to wiring your asking for a fire. This is why I scrapped the French wiring and made up my own loom from scratch
usher
PostPosted: Sun Feb 02, 2014 1:24 pm Up
lol why am i always so far away from help, i woudl like to keep the flames in the engine tho lol, which one is the relay for slow speed the top one or bottom
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sun Feb 02, 2014 1:30 pm Up
no idea Laughing
usher
PostPosted: Sun Feb 02, 2014 1:33 pm Up
lol not exactly on your priority list of things to remember when its not there eh, ilkl do some digging see wether i can find out wich one it is and remove it then its less to worry about
seems that ill solve all issues with a new ecu and loom lol
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sun Feb 02, 2014 1:34 pm Up
Swap the top and bottom one over. Try it again and see if it works
usher
PostPosted: Sun Feb 02, 2014 1:37 pm Up
this looks to be the one single fan twin speed with ac
quality a little bad
ill try that next time im on with it, once thats done i can relax and finish the wiring and sort little isues of interferance
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Sat Mar 08, 2014 4:02 pm Up
finally got round to fitting my lexan windows, the fronts still need securing at the bottom when i cut the inner out of the door, the rears i riveted in but due to the lip from the rubber it ended up bowing the lexan inward Embarassed , i used some silicone to stop it leaking, i recomend bolts with locking nuts for anyone trying this as that would eliminate the bowing and with spacer between would help, mine are stuck now so no going back, i could drill out the rivets and replace with bolts but the silicone i used is also a strong glue Rolling Eyes
ill weigh the glass to add it up im guessing 5 kg and with door inner it should be near 10kg in total bringing the new total to near 170kg removed
also got some std seat runners and some steel to make the subframes for the buckets
next pllan is to re wire the rad fan then once its all running how it was ill be cleaning it up inside and removing lugs etcc
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sun Mar 09, 2014 3:54 am Up
looking better all the time mate...... FCS showdown Laughing
usher
PostPosted: Sun Mar 09, 2014 4:59 am Up
haha i wish discs and pads are still needed and a cage, out of interest what do you use on the rally car discs and pads wise
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sun Mar 09, 2014 5:03 am Up
I have brembo calipers, pads and discs up front with pagid pads and cheapo discs on rear.... I am not a great believer in the hype of expensive is best Wink
usher
PostPosted: Sun Mar 09, 2014 7:18 am Up
Brembo pads up front just std type or fast road etc im looking at pagid blue as herd really good things about them and yeah cheapo discs all round a groove is a groove at end of the day. Also considering ferrodo ds2500 as there rated by alot of members and a lot cheaper
project thread WIP
garage
FAQ
206 gti firedance
shell-vt
PostPosted: Sun Mar 09, 2014 8:18 am Up
Trade Rating: +46
THEM WINDOWS LOOK REALLY WELL . think im selling the gt now whats left of it anyway..
york 16,3
Page 12 of 18
