Latest: ArtistKS
Overall: 17145
Online Now [90]:
Visitors: 89
Today: 15317
Total: 115976992
Forums › The Car › 206 Problems › Door Membrane and Rubber
Razor34
PostPosted: Mon Jan 27, 2014 10:11 am Up
Hi,
Got a problem with water leaking in the rear n/s door and I have done the usual of checking the drain holes etc.etc. I have asked for a cost from peugeot for a new door membrane and door seal rubber and it comes in at £65.00. Does this sound ok or to expensive??
Vehicle is a Pug 206 1.4 GLX 5 Door
Ray
iainlovatt
PostPosted: Mon Jan 27, 2014 10:32 am Up
bit expensive, second hand value would be less than £10. Smile
(My Garage)
Lowiee
PostPosted: Sun Feb 02, 2014 4:41 am Up
i found water gets in both my n/s door seals after the car misting up so after taking door cards off and tracing the water route it was just a simple case of re aligning the lock plates so the top of the doors shut tight against the seal you could give it a try first seems to be a weak area just at the top and when the water runs down it flows over the seal at the bottom onto the carpet making it hard to trace
Razor34
PostPosted: Tue Feb 04, 2014 10:08 am Up
Will give that a go - thank you
Ray
