Posted: Sat Feb 08, 2014 1:13 pm |
Want to set my rear suspension back to stock height what's the measurement from the chassis to the arm or even the attachment point to the arm
| GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow | |
Posted: Sat Feb 08, 2014 1:32 pm |
Height between the ground and the rear jacking point on the sill should be 133mm (+14mm, -11mm)
Posted: Sat Feb 08, 2014 7:21 pm |
well the suspension is off the car.. so need a measure of the arm to body so that i can get a correct height
Posted: Sat Feb 08, 2014 8:44 pm |
how to set up original ride height?
Posted: Sun Feb 09, 2014 2:11 am |
the dummy damper length would work too
