Online Now [1444]:
Visitors: 1443
Today: 26172
Total: 151163968
Forums › The Car › Request a how-to › Removal of the 3rd brake light. 206 2001.
stuarts30
PostPosted: Mon Feb 10, 2014 9:02 am Reply with quote Up
Hi all,
I have searched through the site and found nothing.
If somebody could inform me how to remove and change the entire 3rd brake light that would be great.
Some idiot tried stealing my rear washer jet from within the light so got to replace the entire thing.
Cheers.
PostPosted: Mon Feb 10, 2014 9:21 am Reply with quote Up
Two nuts on the inside of the tailgate behind the third brake light. Unscrew these and if you're lucky it will lift out from the outside. If you're unlucky, it might need a little persuasion with a mechanics screwdriver Wink .
Unclip the loom and the water pipe.
Refitting is the reverse, without the persuasion.
stuarts30
PostPosted: Mon Feb 10, 2014 9:22 am Reply with quote Up
Thought as much, i failed at the persuasion part :). Do you know if all models come with the water jet?
  Quick Reply
Username:
Message:
Quote the last message
