Latest: heikkisj
Overall: 17126
Online Now [108]:
Visitors: 107
Today: 13136
Total: 100346128
Forums › The Car › 206 Talk › replacement rear axles ?
cartoonhead
PostPosted: Mon Feb 10, 2014 4:26 pm Up
apart from the different ABS sensors/plugs are pre-plexed and multiplexed rear axles the same ?
Ie can you use a pre-plexed rear axle on a multi-plexed car ? ?
iainlovatt
PostPosted: Tue Feb 11, 2014 2:42 am Up
Think leethr has done this! im sure when he is up he will confirm! Smile
(My Garage)
PostPosted: Tue Feb 11, 2014 2:54 am Up
The only other difference I know about is in 2003 the trailing arms had the bosses cast into them for the lateral links fitted to the 180 and SW models. I've also heard later axles were round in section as opposed to the square/triangular section of earlier versions.
Earlier axle is below.
cartoonhead
PostPosted: Tue Feb 11, 2014 2:09 pm Up
problem i came across was i tried to fit the multipled sensors in the preplexed axle and the ends of the sensors was rubbibg on the ABS rings Sad
was thinking maybe at worst i could cut the plugs and swap them over as there is only 2 wires in side them.
