Online Now [345]:
Visitors: 343
Bots: 2
Today: 99246
Total: 156206067
Forums › The Car › 206 Problems › Car slow down when foot on the gas
AJ2013
PostPosted: Wed Feb 12, 2014 5:22 pm Up
Recently when I am driving say 25mph with my foot on the gas, the car seem to slow down for few second and start to speed again. I dont have my foot on the clutch. Also noticed when I am turning and putting my foot down to gather some speed, the car want to slow down for few second.
Someone was telling me its something to do with a sensor which is preventing fuel being released to power the car.
thesigma3
PostPosted: Thu Feb 13, 2014 2:52 am Up
either that or a misfire? get it into a garage for a check
mattymj
PostPosted: Thu Feb 13, 2014 7:35 am Up
Maybe you are also pressing the brake as the pedals are quite close together?
PostPosted: Thu Feb 13, 2014 12:40 pm Up
my dads had this problem, i replaced the throttle position sensor and the map sensor. cheap to replace and only only takes 10mins to do, worked a treat.
what engine is yours?
PostPosted: Sun Feb 16, 2014 12:15 pm Up
I have just woken up after a 28hr shift so am tired and really grumpy and this thread has annoyed me. The summary of posts so far is - throw some parts at it and it might fix it. Come on children that is not the way to fault find and very quickly gets expensive.
If nothing else clear existing fault codes. Drive it for a few days and then re-read the codes.
TPF might be a correct diagnosis but no supporting guidance except my dad's car did this and that fixed it.
AJ2013
PostPosted: Tue Feb 25, 2014 1:33 pm Up
I spoke to Peugeot garage and explained the slowing down of the car. The guy at parts explained its a possibility the Ideal Regulator Motor (Stepper Motor) may need replacement.
A colleague of mine explained that he had similar problem with his and his garage charged him £250 to replace the sensor at the catalyst convertor because the senor may be limiting the amount of fuel being transferred resulting in car slowing down.
danhodson
PostPosted: Tue Feb 25, 2014 1:39 pm Up
I had an old corsa that had this issue, the catalytic convertor had gone, not sure its the same setup with a pug.
AndrewR2211
PostPosted: Tue Feb 25, 2014 5:54 pm Up
Shocked
My 206 Sport
PostPosted: Fri Feb 28, 2014 12:37 pm Up
Lots of threads on this forum and a "how to" on cleaning stepper (idle control) motors.
Do a search and, if that is your problem, simple and cheap DIY fix.
