Posted: Mon Feb 17, 2014 2:49 pm |
Hi,my fob was missing the rubber cover over the lock button so being lazy I have been just clicking the little black one on the circuit chip, but the other night I went to lock it and seen it had fallen off.Can I just buy a new circuit chip and just reprogram it? any help would be much appreciated.
Posted: Mon Feb 17, 2014 3:13 pm |
Well you can do that,but it has to match the last letter on yours like "C" or what ever you have,and reprogram it with PP2000,and you need to have the 4 digits security code.
BUT.....
You can save all the hassle,by having the replacement kit (comes 2 buttons),and you can replace the one is faulty,and all will be back great,and with a new fob ofcourse.
Posted: Mon Feb 17, 2014 3:15 pm |
Posted: Tue Feb 18, 2014 1:19 pm |
| Timon2210 wrote: |
BUT.....
You can save all the hassle,by having the replacement kit (comes 2 buttons),and you can replace the one is faulty,and all will be back great,and with a new fob ofcourse. |
Thanks for the reply, so will that new button work straight away once connected to the circuit?
Also do you know anything about electric windows? my right one started making a kinda crackiling noise the other day and now it stops about 25/30ml from the top and won't close fully,it's very slow and squeaky going up and down now aswell
Posted: Sun Feb 23, 2014 2:08 pm |
You are welcome,sorry for the late reply,well as you connect that button to the circuit,everything will be back to normal :).
About your window regulator,you need a replacement,try scrapy yard for a second hand one.
Posted: Sun Feb 23, 2014 3:25 pm |
Can confirm - I had to re-solder mine the other week, only took two minutes and worked fine.
