Posted: Fri Feb 21, 2014 5:17 pm |
| kwakzx7r wrote: |
| I thought the whole point of this forum was to help those that needed help, not to tell them to take it to "someone who knows what they're doing" If someone has the confidence to try and do it themselves then with the right help there is no reason why they shouldn't be able to do these jobs themselves, learning how to do it and have the knowledge to pass onto others !! |
Cars kill.
Posted: Sat Feb 22, 2014 1:20 pm |
| V9977 wrote: |
| kwakzx7r wrote: |
Cars kill. |
LOL and thats it!! lmao So every self taught mechanic on this web site and others must be lucky to be alive !!
Posted: Sat Feb 22, 2014 2:06 pm |
| kwakz wrote: |
| V9977 wrote: |
| kwakzx7r wrote: |
Cars kill. |
LOL and thats it!! lmao So every self taught mechanic on this web site and others must be lucky to be alive !! |
So does that mean being trained by PSA peugeot citreon I wont die?
Awesome
| Team Impossible Possible
Posted: Sat Feb 22, 2014 8:19 pm |
So, back to the topic. We re-timed the motor and it starts. For about 1-2 seconds. However it stalls and shuts down. If i leave the ignition on, the engine light stays on and so does the battery one. Then if i start it agin it starts, but then shuts down. Is the ECU plug the steering wheel fuse compartment? ill link a pic of the plug. I disconnected the coilpack sensor, battery, cam sensor plugs. On these motors do you have to reset any ECU's? if so how?
Posted: Sat Feb 22, 2014 8:34 pm |
| Aaron180 wrote: |
| So, back to the topic. We re-timed the motor and it starts. For about 1-2 seconds. However it stalls and shuts down. If i leave the ignition on, the engine light stays on and so does the battery one. Then if i start it agin it starts, but then shuts down. Is the ECU plug the steering wheel fuse compartment? ill link a pic of the plug. I disconnected the coilpack sensor, battery, cam sensor plugs. On these motors do you have to reset any ECU's? if so how? |
| Quote:: |
Multiplexed Electrical System
When disconnecting the battery to do electrics, or just to change it, you need to follow this guide. Failure to do this could result in a £600 bill from Peugeot!
* Put down the drivers window.
* Pop and Open the bonnet. Shut ALL DOORS apart from the bonnet.
* Leave the car for at least 3 minutes. This allows the BSI to shut down and go to "sleep."
* Disconnect the clamps on the battery, and change/do electrics/whatever you are planning to do.
* When reconnecting, reattach the clamps on the battery. Don't shut the bonnet yet. Leave the car for a few more minutes. This allows the car to settle.
* Lean through the drivers window, and turn the sidelights on. (Don't open the door.)
* This is called a "Soft Start" for the BSI.
* Let the car finish thinking about everything, and check all the systems etc.
* Start the car.
Posted: Sat Feb 22, 2014 8:41 pm |
Thats the same for most modern cars man... and yes that was done.
Posted: Sun Feb 23, 2014 2:09 am |
The problem is your compression. Have you retested it, how many teeth were you out, and on which side?
Posted: Mon Feb 24, 2014 6:08 pm |
Okay so i read the fault codes through my phone using an OBD2 scanner of a friend, and timing on camshaft A (inlet) is infact still out. Thats the problem. Timing this engine is a B****
Posted: Tue Feb 25, 2014 6:06 am |
| Aaron180 wrote: |
| Timing this engine is a B**** |
It is for someone like you that's obviously out of there depth
Posted: Thu Feb 27, 2014 7:41 pm |
Yeah last time im touching the poxy thing i can tell you! Know anything about the intake cam advancing and retarding? and how can it be reverted manualy?
Posted: Sun Mar 02, 2014 1:32 am |
Car runs perfectly now, there were NO BENT VALVES, and no other faults. The timing was off, there is also 2 pin holes for the intake cam. That is what threw us off. Finally finished now and loves the sounds of the engine now it works.
Posted: Sun Mar 02, 2014 7:49 am |
Fair play mate, glad to hear it's running. Perseverance is king
Posted: Sun Mar 02, 2014 3:01 pm |
You are so lucky to have got away with that. Well done for persevering.
Posted: Sun Mar 02, 2014 4:12 pm |
Very lucky! Have you driven it? I ask because just because it runs doesn't mean its timed up right
Posted: Mon Mar 03, 2014 12:45 am |
Not lucky, i just knew the basics.. e.g. when people told me the valves where bent i knew they werent, i have a good understanding of how engines work, just never worked on a floating crank weird french setup but hey... learn something new everyday. Nah havent road tested yet, but it will run fine.
