Online Now [422]:
Visitors: 421
Today: 85671
Total: 154647451
Forums › The Car › Request a how-to › PIN Code in BSI
PIN Code in BSI
Dragas
PostPosted: Mon Feb 24, 2014 3:20 pm Reply with quote Up
Hello
I`ve a BSI version B2 removed from a 2000 Peugeot 206 1.6 GTI. I want install it in my car but i don`t know de pin code of this BSI... I need unlock that or put another PIN.
I`ve the cable for Lexia/PP2000 but in PP2000 doesn`t have the possibility to change PIN or to see the PIN saved in BSI... Do you know another program to read the PIN and change it using Lexia/PP2000 cable?
This is the used cable...
PostPosted: Mon Feb 24, 2014 3:54 pm Reply with quote Up
Well NEVER use the PP2000 clone to do any update to your BSI,as it's very risky,and you might end with have no working BSI at all,and you will have to replace it with a new one,so I recommend that you visit the Dealer in this case,as it's the safest option.
PostPosted: Mon Feb 24, 2014 4:27 pm Reply with quote Up
You cant reset the pin/trans code. One time only unless you get a specialist to remove the imbolliser function off the circuit board
qwert
PostPosted: Tue Feb 25, 2014 1:07 pm Reply with quote Up
you need to read the flash or eeprom on a bench. Can't be done by OBD
brum brum
Dragas
PostPosted: Wed Feb 26, 2014 2:55 pm Reply with quote Up
Ok thanks all
  Quick Reply
Username:
Message:
Quote the last message
