Posted: Mon Feb 24, 2014 2:19 pm |
could someone have a look at these
they have been removed from a ph1 h4 206. will they fit my Gti180. will i need to mod anything to get them to work?
Posted: Mon Feb 24, 2014 3:26 pm |
Have a look at mine that I fitted this week mate, in the first pic there is a brown wire, thats your earth which should have an m6 lug on it, you'll notice that the h7 adaptor is the black block with 3 spade like black shapes going into it with the main headlight wiring going off to the right
In the second pic there is a smooth shape black cable, thats the fuse box wire, I had to fit a fuse to this cable before securing it to the bolt which you'll see when you take the cover off, think i used a 13mm lug and a spare nut to secure it
Posted: Mon Feb 24, 2014 3:40 pm |
Direct fit, see the grey female block, that's the h7 adapter that allows you to put the morettes on your car. They are not h4 due to that!
Posted: Mon Feb 24, 2014 4:54 pm |
I second that motion
